Hi I have this action camera and want to use my pnone as a view finder.
previously when i first got this camera i installed playmemories wifi software and it all worked
i've installed the latest version of the software and it is not compatible with my phone android 4.0.3 I found what i think is the correct version of sony PM software Vers 2.1 and hey presto it installed launced found the camera and allowed me to imput the password. then just as it was arriving at the live image feed it stated error this is not a supported device.
what is going on? can you help
Hi there,
It's a tricky one... Maybe Support can help?
http://www.sony.co.uk/support/en/product/HDR-AS15
Thanks for the response
