I want to buy an Xperia 5 but on Amazon it tells me I can't use it in Ecuador, where I can buy a released Xperia 5 for any country?
Hi again @Eternamente and thank you for the quick reply!
It may very well be the case that the phone you found on Amazon is branded to a local service provider in the states, however as this is a global support forum, I am afraid that I have to refer you to your local support team for further assistance in this query.
Have a nice day and a great weekend!
Hi @Eternamente and welcome to the support forum.
As this is a globally based support forum, I believe that this question would be best answered by your local support team. They should be more than capable to answer whether Xperia 5 is available on your market or not. Simply click on the link below and choose your country or region in the dropdown list.
https://support.sonymobile.com/global-en/contactUs/
I hope that helped a little bit!
In Ecuador they no longer bring the new Xperia smartphones, so I wanted to buy in Amazon USA but says that it only supports SIM from that country, I would like a link from where to buy it released for all countries...
