go to the Contacts app -> 3 lines on the top left -> settings -> default account for new contacts
what do you see there? It should be set to your google account
Yes it is set google account.
But do no want to use google contacts. I save my contacts in the phone with app True phone dialer.
Now I have to make copy of my contacts before I install or temove some apps becouse My phone contacts are deleted. It happens not always.
Looks like a bug with the True caller app... You should get in touch with the app developers
I tried to do the same with my colleague's Huawei also android 10. All is ok on that phone. Contacts are safe on phone.
Today I connected to the Facebook with Facebook app. when connect I lose contacts. Import contacts and when disconect - lose contacts again.
I wrote to sony and to true phone - no answer from bouth
Just because an app works well on a phone does not mean it is optimized for all the phones as well...
Today I removed True phone and intaled another phone app which can safe contacts in the phone.
With new app the same. I lose phone contacts on the same situations.
I think it some wrong with Sony soft.
I wrote to Sony again.
And if they think that is normal to lose contacts - it is really my last Sony phone.
Merry Christmas!!
Could you install on your Xperia 5 install True phone dialer (True Phone
https://play.google.com/store/apps/details?id=com.hb.dialer.free)
create some new contacts and save them in phone's memory. After open synchronize google contacts or open Facebook app and login or logout.
After see is still these new contacts or you lose them.
Thank in advance
Thank for your testing.
Some is wrong. It is not solution deny another apps to connect to contacts or some else if they need it for well working.
when I synchronize contacts with google - my well pictures on contacts become with very low resolution, but also very strange not all.
I found simple sulutions. I seve contat on the phone as google acount but not sinchonize contacts with google.
It seems all work well on the phone now.
By the way - no answer from Sony concerning this.
I have THe xperia 1 and not the 5 but Will attempt to address your urgent questions.
It is hard to accept when you pay a lot for your smartphone and it does not work as intended.
Some features are not there, microphone jack, wireless charger.
Options change, that's how it is.
My advise is to dive into the Support app and read the Xperia tips (top of forum) to learn how to have full profit of what is present.
Xperia 5 is a magnificent device, 21:9 is a very nice alternative to the prior screen format and Xperia 5 fits very good in the hand.
Adapt a bit and enjoy what you have.
Oh and BTW. (for @abrolenas and many, many others)
Android is Google and Google is everywhere.
Take it for granted or do not buy an Android phone.
Enjoy synchronisation of addresses, photos and whatever instead of trying to hide information.
Google has access anyway whether you like it or not.
Use the power of Google assistant and everything else that is built into Android to smarten your life.
From Google you can run, but you cannot hide.
