hello , dear dev Sony Xperia :
i'm tired , always take me charger with me .
the last update was catastrophic and panic with battery life and also performance software . some many time snapdragon 855 llaaagggy in android one , i didn't understing,.
#my-suggestion :
-battery life improvement .( stop application in background it takes a lot of Ram and Processing.
- adapt hardward with software for best user experiance and use all options in Snapdragon 855
- sécurité update , often any last update , we need more privacy here Sony.
*flagshap of 2020 doesn't mean he never takes care , in this moment i don't understood politice of Sony 2 phone no more update , look at apple , plz dev help us .
* Thanks
You're challenging the device.
Stop apps active in the background from being active.
You're probably already aware of the settings.
Still:
- Stop background activity
- Set WiFi preferences to WiFi doesn't turn on automatically.
- This means that WiFi will stay turned off as long as your device is locked
- Set WiFi and Bluetooth scanning off (better for privacy as well)
- Uninstall a lot of apps that you don't use every day.
that need update not talking me friend , the application need to stop in background automaticly , i kewn i disable all option but this update was catastrophic for battery , update update and thanks
smartphones sometime face that issue after the update as the device starts to adapt with the new operations, and it should be rectified after that .
Try to check the information in this link, they can help: https://www.sony.co.uk/electronics/support/articles/00232835
