Partially the blame is Google but also Sony
The quick links of pull down menu are huge! Just two (2!!) buttons fit on the one line - shame Google.
Screen capture doesn't work via power button but needs also Vol-
Also opening the screen 'eye candy' animation should be disabled, just wast of time
But even worse the old 'features' are there 😞
Auto screen brightness dims the screen in too light conditions but doesn't dim any further for the dark environment. It should 'learn' according the user's preferences but I haven't noticed that.
And the new one
The Battery usage monitor graph doesn't show the battery drain since last charge but randomly just some minutes/hours back. The Stamina functionalities have been one strength of Xperia and this is heading to bin.
And more:
One finger view;
Previously it zoomed the screen on the bottom corner
And now;
I moves the visible screen downwards 1/2 the screen. What the heck is this??? The width remains the same but you loose the access on the the bottom section of your screen view. Totally useless!
