Has anyone else had this error message on service test....
When you dial *#*#7378423#*#* and select fingerprint.
Sensor not ok...
Please let us know if it's a common issues or a hardware issue.
I have the same issue, it started after Android 10 update / also my ringtone for messaging app is custom it does not work and sometimes work.
I have a feeling it is Android 10 giving these problems.. phone was working flawlessly with Android 9 OS
May be just a problem with Android 10, hope it's just a software issue
I think it's from SW issues.
Did your SW version is 55.1.A.0.748
Yes my software version is 55.1.A.0.748 this is just aggravating, I emailed Sony, they emailed back saying call this 1800 number, being the holidays I can't do anything yet, if anything hopefully I can send it back to Sony under Sony warranty get this issue resolved. I love the XPERIA line. I've owned xperias from XPERIA z1, z5, XZ and this XPERIA 5
True, I hope it's just a software issues. Let's see. I will also need to contact them.
Hi it's Android 10 that gives the error.
I had my Xperia 5 replaced by my retailer, New one was fine on Android 9 but after I updated it to Android 10, it now says sensor Not Ok.
So most probably a software issues. Hope Sony will fix it.
