When i connect the phone to my PC, nothing happends.
If i go to USB settings in phone, i cant change anything.
What to do?
Hi!
Thanks for the reply.
I tried another cable, and then it worked!
The first cable i tried, was from my old Huawei.
But still weird, a cable should be a cable right?
No, not all cables are equal.
The cables have to be electronically marked cable assembly (EMCA) and support "SOP" packets. It must respond to the "Discover Identity" VDM sequence* with a cable VDO packet with bits 6..5 set to indicate 5A current handling capability.
Supported current, and other gubbins matter.
* - USB-PD section 6.4.4.3.1
