I have WiFi calling back on my phone but I'm not sure how. I swopped the SIM from 1 to SIM 2 and then back again and restarted the phone and the provision was there. Unless Sony had sent a patch from my case number to rectify the issue?
There is an option to update network settings in the phone call menu which triggers a Vodafone set up for wifi calling that often needs to be done after a major update. It will do it itself eventually so could have been that being triggered.
Hi there, did you manage to solve the issue by swapping the SIM card place ?
Hi, thanks for the reply. I can only find 'reset network settings' under system-advanced-reset options. Whether this is the same?
Wifi calling reappeared after I put the sim card into the sim 2 slot and then put it back into sim 1. Unless it was a coincidence. I've restarted the phone a few times now and all is good
