Hi, after upgrading my 5 II to android 11, this app stopped working as before:
https://play.google.com/store/apps/details?id=io.appground.blek
It makes use of the Human Interface Device Bluetooth profile that was added in android 9.
Can anyone else confirm that this app runs in "compatibility mode" on android 11? (it didn't on 10.)
2 things
- try resetting Bluetooth, find reset in settings.
- for problems with AIDS contact the app developer.
Resetting doesn't work.
As for the second point, this very likely isn't an app issue but a firmware one, they have broken support in the update and it's up to them to fix.
You can use this app to test support too:
https://play.google.com/store/apps/details?id=com.rdapps.bluetoothhidtester
Hi Bzzrak,
What's the model number of the TV? You'll find it on the side/back of the TV. Also what is the software version of the TV? You can find it along with the model number by pressing the help button and selecting system information.
Regards,
Gladio
