Hi. How can I restore a conventional navigation system for the home screen on this new device. The older droid 13 had the three symbols at the bottom but now there's just a single bar which swipes upward but no return function. Does the solution lie somewhere in the settings menu? It's not intuitive at all and infuriating to use.
Hey @Grendow04
You can have the navigation buttons on the home screen by going to settings-system-gestures-system navigation-3 buttons navigation.
You can find this link as a reference to the home screen options from the help guide of the device
