On my phone I cant get a signal.
The Aeroplane mode isn't on, I've taken out & put my sim back in.
Restarted & done a factory reset on the phone & used the downloadable software on sonys website to check to see if this would sort the issue but hasn't sorted the issue just wondering if anyone else has had a similar problem?
@Zathrus I think from what you tested with the phone it seems that it might be a SIM card issue, so you can check the network indicator in the status bar if it is empty you will need to test the SIM with a different device and if is doing the same with the other model you will need to check it with the network provider so they can help.
I have tried my sim in a different phone and the sim seems to work ok in this phone.
Despite this seeming a bit odd, so I'm non the wiser
Despite having the sim for quite a while now & the sim working well on the 4G network on the network I'm on.
I've tried the sim in a different phone and don't have any issue with the phone or sim being stuck in what seemed like aeroplane mode or not getting any signal
Again I tried all the steps in the link & done a factory reset & used sonys own app to repair/fix & or update the phone & it didn't work.
