On my previous XA1 I was able to enable/disable data in settings and I did that because I have a paygo small bundle on VFone and I got caught out once outside the home (I use the data thru my wi fi at home which is fre)
Have now bought a new Xperia 10 IV which with the help of all of you I have set up now but.......the instns tell me to use fingers from top of scren down and there will be the option - but it is not there! I cannot find it anywhere in my settings!
I do not want to be caught out if I leave the house and use data by mistake as I only get 100mb but am very elderly and do my emails and searches at home.
Where is it? or is it automatic on this new model
Thanks everyone
Gordon
Hi @mogggie
The way I do it is by swiping down on the home screen, then clicking the top left tab (internet), then turning off the mobile network internet connection there.
Hope this helps.
Hi @mogggie
Hope this helps.
THanks so much for this answer - I would never have found that! I did what you said and it solved my problem
Suberb!
Gordon
