Yesterday I updated a new my #Sony Xperia 10 plus with the latest firmware, since then my phone has been freezing, can't access my apps and my battery is draining very fast. Am I the only one having this problem ?
Can you share which apps in particular.
So far i noticed foursquare app.
Battery drain is normal even before this update. Use greenify. Stamina mode does not help
Never had an issue with the battery until the update, regarding the apps, been having big issues with Youtube and Netflix, after I use these apps the phone doesn't respond, I can see the video playing but I can't forward, pause, etc, I have to block the phone for a few seconds then unblocked it so it can work properly.
I noticed when watching YouTube videos. The battery drained very fast. Also, I just use it for a simple task like reading an article, no speaker on, and the screen display brightness set below middle, the battery drained very fast. That I already has the stamina mode turned on as battery time preferred. The estimated time of the battery life in the stamina mode is not correct.
Wow!! Gets worse every day, now the play store app doesn't work, I had to rest my phone a couple of times today so it can work properly.
