How can I swap round the navigation bar at the bottom so the back button is on the right not the left, cheers
Hi @KezzaRed, sorry for the late reply to your post!
With the default launcher, it's not possible to change the order of the icons in the navigation bar, however you may be able to do this if you download a different launcher from the Google Play store.
I hope that answers your question!
