Bjr je souhaiterais savoir savoir quelle prise hdmi acheter pour brancher sur mon portable xperia 10 plus et ma tv pour que je puisse regarder tv en direct, car je ne possède pas d'antenne juste un écran, merci
Bjr I would like to know what hdmi socket to buy to connect to my laptop xperia 10 plus and my tv so that I can watch live TV, because I do not have an antenna just a screen, thank you - GT
You don't need a cable to connect your X10+ to a TV.
The connexion use Wi-Fi Direct technology to creates a wireless connection between the two devices.
/!\ Your TV must support Screen mirroring based on Wi-Fi CERTIFIED Miracast for the function to work.
See here for more info: https://support.sonymobile.com/global-en/xperia10plus/userguide/mirroring-the-screen-of-your-device-...
