I tried to add shortcuts to home screen from several apps but it's not working.
I tried to pin chart from WhatsApp and telegram
I use the default launcher
I have the Xperia 10 Plus
Here is a chrome screen shot of "add to hope screen"
Is it possible that the shortcut then disappeared in the side screen from the home screen.
Try swipe sideways to see if it's hidden there.
No
Nothing there
OK, I have escalated it and received an answer in the Pioneers section saying that it works as expected, also from within the app, WhatsApp.
Conclusion: there must be a hickup on your device, whatsoever.
Normal action: how is it in safe mode.
Regrettably 3rd party apps don't load in safe mode.
You could try to hunt the culprit, the 3rd party app that maybe causing this aberrant behaviour on your device.
That will take a long time.
Better take a shortcut.
My suggestion is to do a software repair using Xperia companion.
Make a backup first.
After the software repair, DON'T restore the backup. Just install WhatsApp and see if you can create the desired shortcut.
Is that is successful it is a 3rd party app that caused your problem.
If not I am at the end of suggestions.
Sincerely hope you will find a way to get what you want.
Actually i also have the sound issue in whatsapp like other people posted here
So i will return thr device anyway
Thanks again
When you first got your phone have you updated it?
Whatsapp for Busness
