Hello there, How do I disable burst mode photos? There is no option in the camera settings.
I have configured the camera to use the volume button as the shutter but I keep taking burst photos by accident. I know the button shouldn't be held down but I want to stop this happening by accident (which seems all too easy) as I very rarely will want to take burst photos. Grateful for any help. Thanks!
Hey @ jim1001
I actually contacted Sony and unfortunately, they've confirmed the same, that there is no option in the Xperia 10 called burst with camera Key.
I believe what happens with is that if you press and hold on the shutter button that when it starts to take photos in burst mode, right?🤔
Yes, I said that I'd contacted Sony Support in the solution
Yes that's correct. If you need any more help you may be better starting a new post. This one is finished now as far as I'm concerned so I won't be posting again on it. Thanks all the same!
