- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
App drawer search bar over some symbols
Hey,
I found a bug in the appdrawer. Sometimes the search bar goes over the top bar and overlays on other symbols/clock.
Please fix this issue.
Another request is to have an option to put the search bar at the bottoms of the appdrawer so it's easier to access with one hand
Thank you!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hey @soderdaen
-When did that start to happen? Does it happen all the time, or is it a temp glitch?
-Try to force restart the device and check again.
Could you also, provide the device's model to be able to check?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- it started to happen from the beginning. When I restart the device, everything is alright, but after some usage the search bar is travelling up more and more
The device model is XQ-ES54 with all updates installed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That onl worked after restarting but then the search Bar is moving Up again.
I guess its a Software issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@soderdaen I'd recommend you go with the software repair to clear any bugs in the current software
