Accessibility, green squares and voice prompt - how do I delete? Sony X10. Also please tell me how I activated it so i do not do it again...Thanks
Hi @ZASquire, let me see if I can help out here.
As @alexdon mentioned, you seem to have activated a feature for visually impaired users called Talkback. In order to deactivate Talkback, please follow the steps below.
9 out of 10 times this mode is activated by pressing the volume key in both directions simultaneously. If you want to deactivate this shortcut, find and tap Settings > Accessibility > Volume key shortcut > Turn off.
Let me know if that helped!
@ZASquire there you go:
https://support.sonymobile.com/global-en/xperia10/userguide/talkback/#gref
It is a mode for people with dissabilities.
Awesome - thank you - it worked 🙂
No worries @ZASquire, glad I could help!
Let me know if you have any further questions regarding your phone!
