I have an Xperia 1. Latest Android update installed yesterday. fingerprint scanner seems to have disappeared. I've looked on lockscreen settings and it doesn't seem to be there. Pin only. Very annoying. Any thoughts?
What if
you type finger in settings?
I hope not, but if your situation it's like mine, then the fingerprint sensor doesn't work
go to
settings > support > Xperia tests > scroll to the bottom > Fingerprint sensor
if you get to the part to scan your fingerprint but it doesn't read anything then it seems like a hardware issue.
You could still reinstall the latest update with Xperia Companion, make sure that you backup everything
It doesn't recognise my fingerprint or even that I am putting my thumb there. Will try a few restarts and see if it works. Total nightmare for online banking.
Very odd. Did a restart. Then ran fingerprint sensor. The sweet spot seems to be much smaller after the latest Android update and I have had to take my case off to get it to work. It worked which is a relief. Always seems to be the fingerprint sensor every update. Thanks for help both of you.
This happened to me after the latest update... When the phone is switched completely off then back on, you will lose your finger print security.
However, when the phone is restarted (not off & on) the finger print security scanner etc works.
Sony update problem... So, unfortunately, don't switch completely off, just restart to keep the finger print sensor working
