Neue Alpha a7II in Japan vorgestellt
profile.country.CH.title
alphaholic
Vielschreiber
In Japan wurde heute Nacht die A7II Vorgestellt. Es handelt sich um die erste Spiegellose Vollformatkamera von Sony mit 5-Achs bisldstabilisation.
Hier ein Video und die ersten erhältlichens Specs:
Imaging element 35mm full size (35.8 × 23.9mm), “Exmor” CMOS sensor
Camera Effective number of pixels About 24.3 million pixels
Total pixels About 24.7 million pixels
Imaging element aspect ratio 3: 2
Color filter RGB primary color filter
Anti-dust function
Anti-dust system By antistatic coat and image sensor shift drive
Anti-dust working When cleaning mode run
Manual cleaning working ● run from Menu
Still image recording
Image file format JPEG (DCF Ver.2.0, Exif Ver.2.3, MPF Baseline) compliant, RAW (Sony ARW 2.3 format)
The number of recorded pixels [3: 2] 35mm full size when L size: 6000 x 4000 (24M), M size: 3936 x 2624 (10M), S size: 3008 x 2000 (6.0 M)
APS-C when L size: 3936 x 2624 (10M), M size : 3008 x 2000 (6.0M), S size: 1968 x 1312 (2.6M)
The number of recorded pixels [16: 9] 35mm full size when L size: 6000 x 3376 (20M), M size: 3936 x 2216 (8.7M), S size: 3008 x 1688 (5.1 m)
APS-C when L size: 3936 x 2216 (8.7M), M size: 3008 x 1688 (5.1M), S size: 1968 x 1112 (2.2M)
The number of recorded pixels [Sweep Panorama] Wide: the left and right direction 12,416 x 1,856 (23M), the up-down direction 5,536 x 2,160 (12M), standard: left and right direction 8,192 x 1,856 (15M), the up-down direction 3,872 x 2,160 (8.4M)
Image quality mode RAW
RAW + JPEG
JPEG Extra Fine
JPEG Fine
JPEG Standard
14bit RAW output
Picture Effects 13 Type: Toy Camera (Normal, Cool, Warm, green, magenta), Pop Color, posterization (color, black and white), retro photo, soft high key, part color (R / G / B / Y), high-contrast black-and-white, soft focus (weak, medium, strong), pictorial HDR (weak, medium and strong), rich tone monochrome, miniature (auto, on, middle (horizontal), bottom, right, middle (vertical), left), watercolor tone, Illustration tone (weak, medium, strong)
Creative style * 1 Standard, Vivid, Neutral, Clear, Deep, Light, Portrait, landscape, sunset, night view, autumn leaves, black and white, sepia, style box 1-6
(contrast <± 3 stage>, saturation <± 3 stage>, sharpness < ± 3 stage>)
Picture profile Off / PP1-PP7 (black level, gamma (Movie, Still, Cine1-4, ITU709, ITU709 [800%], S-Log2), black gamma, knee, color mode, saturation, hue, color depth, detail, copy, reset)
Dynamic range function Off, D-range optimizer (auto / level setting <Lv1-5>),
Auto HDR (exposure difference auto / exposure difference level set <1.0EV every six stages between 1.0-6.0EV>)
Color space “Bird Luminous color” corresponding sRGB standard (sYCC color gamut), AdobeRGB standard
Video recording system
File recording method XAVC S
AVCHD standard Ver.2.0 compliant
MP4
Compression format XAVC S: MPEG-4 AVC / H.264
AVCHD: MPEG-4 AVC / H.264
MP4: MPEG-4 AVC / H.264
Voice recording system XAVC S: LPCM 2ch
AVCHD: Dolby Digital (AC-3) 2ch, Dolby Digital Stereo Creator equipped
MP4: MPEG-4 AAC-LC 2ch
Picture Effects 7 Type: Toy Camera (Normal, Cool, Warm, green, magenta), Pop Color, posterization (color, black and white), retro photo, soft high key, part color (R / G / B / Y), high-contrast black-and-white
Creative style Standard, Vivid, Neutral, Clear, Deep, Light, Portrait, landscape, sunset, night view, autumn leaves, black and white, sepia, style box 1-6
Color space “Bird Luminous color” corresponding xvYCC standard (HDMI cable connection when xvColor)
Movie recording shooting mode (XAVC S)
1280 x 720 (120p, 50M) -
1920 x 1080 (60p, 50M) About 50Mbps (average bit rate)
1920 x 1080 (30p, 50M) About 50Mbps (average bit rate)
1920 x 1080 (24p, 50M) About 50Mbps (average bit rate)
Movie recording mode shooting (AVCHD)
1920 x 1080 (60p, 28M, PS) About 28Mbps (maximum bit rate)
1920 x 1080 (60i, 24M, FX) About 24Mbps (maximum bit rate)
1920 x 1080 (60i, 17M, FH) About 17Mbps (average bit rate)
1920 x 1080 (24p, 24M, FX) About 24Mbps (maximum bit rate)
1920 x 1080 (24p, 17M, FH) About 17Mbps (average bit rate)
Movie recording shooting mode (AVC MP4)
1440 x 1080 (30fps) About 12Mbps (average bit rate)
VGA (640 x 480, 30fps) About 3Mbps (average bit rate)
Video features
Audio level display
Recording level adjustment
Simultaneous video recording
Time code / user bits
(TC Preset / UB Preset / TC Format / TC Run / TC Make / UB Time Rec)
Motion tracking sensitivity -
AF drive speed -
Auto Slow Shutter function
Wreck control
HDMI Information Display ● (On / Off)
HDMI video output 1920 × 1080 (60p)
1920 × 1080 (60i)
1920 × 1080 (24p),
YCbCr 4: 2: 2 8-bit / 8-bit RGB
Recording part
Recording medium “Memory Stick PRO Duo”
“Memory Stick PRO-HG Duo”
“Memory Stick XC-HG Duo”
SD memory card
SDHC memory card (UHS-I compatible)
SDXC memory card (UHS-I compatible)
Noise reduction Apply to BULB from NR ON / OFF ***** 1 seconds when long seconds
High sensitivity NR standard / weak / off
Multi-shot NR Auto / ISO 100-51200
White balance
Mode Auto / sunlight / shade / cloudy / bulb / fluorescent light / flash / color temperature setting (2500K-9900K), color filter (G7-M7, A7-B7) / custom / underwater auto
AWB tweak ● <G7-M7 (all 15 steps), A7-B7 (all 15 stages)>
WB bracketing feature Three, H / L switch
Focus
Detecting scheme Fast hybrid AF (phase difference detection method / contrast detection method)
Detection element “Exmor” CMOS sensor
Ranging points 35mm full size at the time: 117 points (phase difference detection method) APS-C size at the time, 99 points (phase difference detection method) / 25 points (contrast detection system)
Detection brightness range EV-1-20 (ISO100 equivalent, F2.0 lens used)
AF mode Single (AF-S) / Continuous (AF-C) / Direct Manual Focus (DMF) / Manual Focus (MF)
Focus area Wide (117 points (phase difference detection method) / 25 points (contrast detection system)) / zone / center / flexible spot (S / M / L) / lock-on AF (wide / zone / center / flexible spot (S / M / L))
Eye Start AF Optional LA-EA2, LA-EA4 use during Allowed
Lock-on AF
Hitomi AF
Other Features Motion prediction
Focus Lock
AF auxiliary light Auxiliary light by the visible light LED
AF auxiliary light reaching distance About 0.3m – about 3.0m (FE 28-70mm F3.5-5.6 OSS)
AF fine tuning Optional LA-EA2, LA-EA4 possible when using
Exposure control
Metering 1200 split live view analysis photometry
Metering element “Exmor” CMOS sensor
Photometric range EV-1- EV20 (ISO100 equivalent, F2.0 lens used)
Metering mode Multi-metering
Center-weighted metering
Spot metering
Exposure Mode AUTO (Random Auto / Premium Random Auto)
Program AE (P)
Aperture Priority AE (A)
Shutter speed priority AE (S)
Manual (M) mode
Sweep Panorama
Scene Selection
Video (program auto, aperture priority, shutter speed priority, manual exposure, selectable)
Scene Selection Portrait
Sport
Macro
Landscape
Evening view
Night view
Handheld Night
Night Portrait
Persons Blur Reduction
Exposure compensation ± 5.0EV (1 / 3EV, 1 / 2EV steps selectable)
(dial operation at the time: ± 3EV (1 / 3EV step))
Exposure Bracketing Single shooting / continuous shooting, shifting amount: 1 / 3,1 / 2,2 / 3,1,2,3EV step, 3 / five selectable
AE lock Half-press during AE lock (auto, ON, OFF selectable)
ISO sensitivity (Recommended Exposure Index) * 2 During still image shooting: ISO100-25600 (Expanded ISO50), AUTO (ISO100-6400, upper / lower limit can be set)
applies to movie shooting: ISO200-25600 equivalent, AUTO (ISO200-6400 equivalent, upper / lower limit can be set)
Finder
Finder
Format 1.3cm (0.5-inch) electronic viewfinder
Total dot count 2,359,296 dot
XGA OLED
OLED -
XtraFine -
Brightness adjustment function Auto, Manual (5 steps)
Color temperature adjustment function 5 stage
Field of view Hundred percent
Magnification About 0.71 times (50mm lens, infinity, -1 m -1 )
Diopter adjustment function -4.0- + 3.0 M -1
Eye point About 27mm from the final optical surface, about 22mm from the eyepiece frame (diopter -1 M -1 ) (***** standard)
Lcd monitor
Format 7.5cm (3.0-inch) TFT drive
Touch panel -
Number of dots 1,228,800 dot
Brightness adjustment function Manual (5 stage), outdoor fine weather mode
Shooting Information Display The graphic display / full information display / No information display / histogram / level / viewfinder for shooting
Angle adjustment function Against the back of the camera
above about 107 °, below about 41 °
WhiteMagic
Switching of the LCD monitor and viewfinder Auto, manual
Screen display switch Graphic display
All information display
Histogram
Level
For viewfinder shooting
Real-time reflection of the setting value ON / OFF
Quick Navi
Focus Check function ● MF Assist (35mm full size when 5.9X, 11.7X
APS-C during 3.8x, 7.7x)
Zebra
Peaking ● (high / medium / low / off) (Color: Red / Yellow / White)
Marker
(Center / aspect / safety zone ./ guide frame)
Grid line
(3 split / grid / accusative + grid / Off)
Face detection
Mode Input / input (registered face priority) / OFF
Personal face registration
Face selection
The maximum number of detections Eight
Auto Framing
When a still image is
Other Features
Smile Shutter Smile Shutter <level set three stages>
Touch Shutter -
Touch focus -
Self-portrait self-timer -
PlayMemories Camera Apps
Shooting advice -
Camera guide
Date and time setting
Area Setting
Demo mode
Zoom ring operation direction
Eye-Fi support * 3
All pixels super-resolution zoom
When a still image is ● (about 2 times)
During movie ● (about 2 times)
Digital zoom
Smart zoom (still image) 35mm full size when
M size about 1.5 times, S size about twice the
APS-C size when
M size about 1.3 times, S size about 2 times
Digital zoom (still image) 35mm full size when
L size about four times, M size about 6.1 times, S size about 8 times the
APS-C size when
L size about four times, M size about 5.2 times, S size about 8 times
Digital zoom (video) 35mm full size when about four times
during the APS-C size about 4 times
Shutter
Format Focal plane shutter Electronically controlled longitudinal
Shutter speed range During still image shooting: 1 / 8000-30 seconds, valve,
when shooting movies: 1 / 8000-1 / 4 (1/3 step), until AUTO 1/60, until the auto slow shutter 1/30
Flash sync speed 1/250 seconds
Electronic first curtain shutter ● (On / Off)
Silent shooting -
Camera shake correction function
Method Image sensor shift method 5-axis correction (by the correction method lens specification)
Correction effect 4.5 stage (***** standard compliant. Pitch / yaw direction, Sonnar T * FE 55mm F1.8 ZA when mounted, when noise reduction off when long seconds)
7 ANTWORTEN 7
profile.country.DE.title
AxelF.
Expert
Moin Moin,
und hier noch ein Video zu Arbeitsweise der 5-Achsen-Stabilisierung.
Gruß
Axel
(Gesetzte Links können immer Werbung für irgendwas gemäß Telemediengesetz enthalten 🙂
Zeig mir nicht Deine Ausrüstung, ich will Deine Bilder sehen!
alphaholic
Vielschreiber
Danke Axel!
Und hier gibts noch alle Specs in Englisch (Hoffe, die Deutschen Seiten folgen bald...)
http://www.sony.net/Products/di/en-gb/products/v6cd/feature.html?contentsTop=1
Gruss aus der CH
alphaholic
AxelF.
Expert
Und hier die deutsche Pressemitteilung dazu:
Sony entwickelt die α7 Serie konsequent weiter und ergänzt die Familie um eine neue Generation von Vollformatkameras. Die neue α7 II (ILCE-7M2) ist die erste Vollformatkamera mit interner Fünf-Achsen-Bildstabilisierung Zudem ist der Fokus deutlich schneller und treffsicherer im Vergleich zur α7. Auch im Video-Bereich hat die Kamera kräftig zugelegt.
Für ihre herausragende Bildqualität ist die α7 ohnehin bekannt. Jetzt kommen in der neuen Generation einige spannende Funktionen hinzu. Allen voran wird die Bildstabilisierung die Herzen der Foto-Fans höher schlagen lassen. Der 24,3 Megapixel Exmor CMOS Vollformat-Sensor ist bei der α7 II eingebettet in einen Fünf-Achsen-Bildstabilisator. Die neue Technologie, die in alle Himmelsrichtungen Vibrationen auffängt, ermöglicht deutlich längere Verschlusszeiten. Bis zu 4,5 Blendenstufen kann der Bildstabilisator ausgleichen. Das besondere Extra: Seine Fähigkeiten zeigt er natürlich auch bei Objektiven, die per Adapter an die Kamera angeschlossen werden.
Fünf-Achsen-Bildstabilisator für verwacklungsfreie Fotos
Auch wenn man noch so sanft auf den Auslöser drückt: Jede Kamera bewegt sich im entscheidenden Moment zwangsläufig um wenige Millimeter. Bei schwierigem Umgebungslicht, wenn die Sonne untergeht und die Belichtungszeiten länger werden, ist das umso kritischer. Gut, dass der neue Bildstabilisator im Inneren der α7 II nahezu alle Bewegungen ausgleichen kann. Er stabilisiert Bewegungen nach vorne, hinten, rechts und links und kann zudem auch kreisförmige Bewegungen ausgleichen.
Das Praktische am neuen Bildstabilisator ist, dass er sämtliche Bewegungen ausgleicht, auch wenn das Objektiv einen eigenen Stabilisator hat. Das ist gerade bei E-Mount Objektiven mit Optical SteadyShot (OSS) der Fall. Hier werden beide Bildstabilisationen miteinander kombiniert. Bei Fremdobjektiven oder Objektiven aus der A-Mount Familie von Sony greift der neue Stabilisator ohnehin zu 100 Prozent.
Gleich nach dem Druck auf den Auslöser lassen sich die Ergebnisse auf dem hochauflösenden Monitor der Kamera mit jetzt 1,29 Millionen Punkten begutachten.
Schneller & präziser: der neue Fast Hybrid-Autofokus
Den 117 Phasen- und den 25 Kontrastautofokuspunkten direkt auf dem Sensor entgeht kein Detail. Sie warten auf der gesamten Sensoroberfläche von der Mitte bis zur Kante auf passende Motive zum Scharfstellen. Und das machen sie besonders schnell und akkurat. Der Algorithmus zur Schärfeberechnung ist nun noch einmal verbessert und macht die Fokussierung rund 30 Prozent schneller als bei der α7. Gleichzeitig hat sich auch die Fähigkeit der Kamera deutlich verbessert, die Bewegung von Objekten vor der Linse vorauszusagen. Autofokus und Belichtungskorrektur werden schneller nachgeführt, so dass Fußball, Kind und Co. immer scharf und optimal belichtet in Szene gesetzt sind. Einmal erfasst, bleiben Motive dank „Lock-on AF“ immer im Fokus.
Darüber hinaus spielt Schnelligkeit auch bei einem anderen Aspekt eine entscheidende Rolle: Die Einschaltzeit der Kamera ist 40 Prozent kürzer als bei der α7. Somit ist die Kamera immer sofort einsatzbereit.
α7 II: der Foto- und Videospezialist
Das Herz der Kamera ist ein 24,3 Megapixel Exmor CMOS Sensor. Lichtempfindlich und hochauflösend ist er perfekt für Aufnahmen in bester Qualität geeignet. Der BIONZ X Prozessor übernimmt die Weiterverarbeitung der Bilder. Seine Detail-Reproduktionstechnologie schafft es, aus jedem Motiv die natürlichen Strukturen herauszuarbeiten. Die Reduzierung der Beugungsunschärfe holt Details ans Tageslicht, die je nach Blendenöffnung verloren gehen können. Zudem analysiert der Prozessor jedes Bilddetail und wendet nur dort eine Rauschunterdrückung an, wo es sinnvoll ist und störende Körnung droht.
Zusätzlich zu Aufnahmen in AVCHD Ver. 2.0 Full HD (1920x1080) 60p, (50p)/60i oder (50i)/24p beherrscht die α7 II auch das XAVC-S Format, die kleine Schwester des professionellen XAVC Formats. Das garantiert Full HD Videos mit Bitraten von bis zu 50 Megabit pro Sekunde. Zudem beherrscht die α7 II Video-Codecs wie MPEG-4 AVC/H.264 im Schlaf. Beim Thema Audio setzt die neue Kamera unter anderem auf linear „PCM“.
Verschiedene Bildprofile geben Videos bereits in der Kamera den gewünschten Look. Zudem unterstützt die α7 II zum Beispiel S-Log2 und erzeugt einen um 1.300 Prozent höheren Kontrastumfang mit mehr Raum für eine weiche Gradation und eine bessere Reproduktion von Lichtern und Schatten. Sie bietet damit maximale Möglichkeiten für die spätere Bearbeitung der Videos am PC.
Verlässlich & gut zu bedienen: die neue α7 II
Gerade bei überdimensionalen Tele-Objektiven spielt die Größe des Handgriffs eine entscheidende Rolle. Daher liegt die α7 II in diesen Situationen besonders gut in der Hand. Zudem ist der leicht vergrößerte Auslöser beim neusten Modell der α7-Familie weiter Richtung Kamera-Vorderseite gewandert. Zehn individuell mit jeweils einer von 56 Funktionen belegbare Bedienknöpfe geben der Kamera in Sachen Komfort den letzten Schliff. Das schwenkbare „White Magic“ LC-Display auf der Kamera-Rückseite zeigt selbst bei direktem Sonnenlicht klare Bilder zur Kontrolle.
Der XGA OLED Sucher glänzt mit einer Auflösung von 2,36 Millionen Bildpunkten und hohen Kontrasten. Er ist prädestiniert zur direkten Bildkontrolle, zeigt auf Wunsch den exakten Fokuspunkt in der Lupenfunktion und hebt die Schärfeebene farblich hervor („Fokus Peaking“). Selbst wenn APS-C Objektive mit der α7 II genutzt werden, zeigt er das Bild verlässlich im gesamten Sucher.
Alles in allem ist die α7 II der perfekte Partner für gehobene Ansprüche von Profi-Fotografen. Das innere Gerüst (Oberseite, Front, innerer Aufbau) ist aus Magnesium gefertigt. So ist die Kamera allen Situationen gewachsen, widerstandsfähig und leicht. Das Bajonett ist besonders stabil und passt somit auch perfekt zu großen, schweren Tele-Objektiven. Selbstverständlich sind Drehräder und Funktionsknöpfe separat versiegelt, um Staub und Feuchtigkeit auf Distanz zu halten. Auch die übrigen sensiblen Punkte wie zum Beispiel der Speicherkarten-Slot sind besonders geschützt.
Kontaktfreudig dank WiFi & Vernetzung mit mobilen Geräten
Selbstverständlich versteht sich die Kamera via WiFi und NFC mit Smartphones und Tablets hervorragend. Zudem bietet sie den Zugang zu PlayMemories Camera Apps, die Einsteigern und Profis das Fotografieren erleichtern können. Die „Lens Compensation App“ zum Beispiel speichert Objektiv-Informationen in den Exif Daten ab, korrigiert Objektivfehler auch bei aufgenommenen Videos und exportiert beziehungsweise importiert Werte zur Anpassung verschiedener Objektive. Nutzer können so individuell die Schwächen ihrer Objektive von Verzerrungen über chromatische Aberration ausgleichen. Mehr Informationen zu den Apps gibt es unter www.playmemoriescameraapps.com/portal/.
Zubehör für die α7 II
Passend zum neuen Body gibt es auch einen neuen Hochformatgriff VG-C2EM. In seinem Inneren finden zwei NP-FW50 Akkus Platz. Je nach individuellem Geschmack liegt die Kamera so besser in der Hand – und ist länger leistungsfähig. Außerdem gibt es eine neue, hochwertige Ledertasche LCS-ELCB. NFC und USB Schnittstelle bleiben praktischerweise frei, so dass die Kamera zwar gut geschützt, gleichzeitig aber auch sofort einsatzbereit ist. Die Augenmuschel FDA-EP15 rundet das Zubehör-Paket zur neuen Kamera ab. Sie passt allerdings auch auf den Sucher der α7S, 7R und 7.
SAL-70300G2: Neues A-Mount Objektiv für A-Mount Kameras
Auch für die A-Mount Kameras hält Sony fürs kommende Jahr eine Neuheit bereit. Die neue Generation des SAL-70300 deckt den Telebereich von 70 bis 300 Millimetern ab und garantiert das unverwechselbare Bokeh der G Objektive von Sony. Mit diesem Brennweitenbereich passt das Objektiv perfekt zu Sport- und Wildlife-Fotografen und gibt ihnen dank einer Naheinstellgrenze von nur 1,2 Metern viele Möglichkeiten. Auch Tele-Makro Aufnahmen oder Porträts passen gut zum neuen Objektiv. Um Blendenflecken bei Gegenlicht und unerwünschte Schatten zu vermeiden, sind die wichtigsten Linsen mit der bekannten Nano AR Beschichtung vergütet. Der Autofokus ist rund viermal schneller als beim SAL-70300G. Auch hier sorgt das Design dafür, dass Staub und Feuchtigkeit nicht den Weg ins Innere des Objektivs finden.
profile.country.de_DE.title
Retired_282425
Alter Hase
Na, da scheint sich die Olympus Beteiligung für SONY ja auszuzahlen.
Genau den Punkt hatte ich schon vor Jahren bei den Nexen kritisiert, das Fehlen des internen Stabis. SONY schlingert ganz schön hin und her. Mir tun nur die leid, die jetzt E-Bajo ohne Innenstabi haben, denn neue stabilisierte Objektive wird's jetzt wohl nicht mehr geben. Und vielleicht lernen sie auch von Olympus, wie man den Phasen-AF im Sensor implementiert so dass die A-Objektive ohne monströse Adapter einen schnellen AF haben. Und mit dem zusätzlichen Handgriff kann man sie vielleicht auch noch mit großen Objektiven gut halten. Dann frag ich mich aber warum sie die Technik nicht einfach in ein A-Bajonett Gehäuse einbauen mit AF-Motor für die volle Kompatibiltät, das wär dann sicher der Renner .....
Viele Grüße aus dem wunderschönen Frankenland mit seinen Farben Rot und Weiß
sendet
GeorgFriedrich
Was gibt es Neues?
Cremantus
Enthusiast
Das Wackel-Thema wird damit ja immer geringer... so soll es sein.Die Funktion an sich dürfte damit wohl state-of-the-art sein.
Und bei allem Komfort ist das Wichtigste, dass man es abschalten kann wenn man will. Das Bild entsteht schliesslich immer noch nach wie vor 10 cm hinter dem Sensor.
Bestens, Tilo
AxelF.
Expert
Das SEL 18200 hat vor über zwei jahren schon TOP Leistungen an der NEX 7 gebracht. Und selbst der Steady-Shot im Gehäuse hat hervorragende Leistungen gezeigt, die sogar besser waren als die Objektivstabilisierungen von Canon und Nikon.
siehe Heise c't Test zur Bildstabilisierung
Fürs kleine E-Mount Format wird es wohl weiterhin die OSS Objektive geben. Und ich denke auch, dass die FE-Objektive weiterhin über einen OSS verfügen werden, da sich in Zukunft die Kameras und die Objektive die Stabilisierung zu teilen scheinen, wie die beiden Bilder verdeutlichen.
Gruß
Axel
Cremantus
Enthusiast
