Hi here
Basically on my Sony RCD W100 drive A will only open with a cd it in if it’s empty you can hear the motor but it will not open unless you press the draw down slightly on the top of the front plate then it opens no problem. Any ideas thanks in advance
Belt was slipping replaced it with one I got from eBay problem gone
