- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
My Xperia Z5 Premium won't turn on.
I've pressed and held the power button. Didn't work. The hard reset is not working. I tried pressing the off button near the SIM and tried turning it on again. Didn't work.
Also when i hook it onto the charger the notification light doesn't light up. PC Companion isn't recognizing it either.
Please help!
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi BlazeAwesome,
Welcome to the community,
Before attempting the software repair try the following.
Hold the power button and volume + key for around 15 seconds, once done immediately connect to a charger and keep it on for around 1 to 2 hours.
See if you can power the device on, if no follow through with the provided instructions.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you alexdon and Jake.
Jake, I tried what you said but it still is unresponsive. I'll go ahead with what alexdon suggested.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Keep us updated.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I've reached the part where I have to make sure my phone is turned off and connect it to the PC. I'm sure the phone is turned off but it doesn't proceed to the next step.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Can you try to charge the device for 2 hours before trying this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'll try that and get back to you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Still not working.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
So turning the device off, starting the repair process and connecting with volume down pressed doesn't trigger the repair?
