hi, I just got my Z5P and I really like how to fingerprint sensor works and it perfects, but I realize that is a proble. I set up so that if it's the wrong fingerprint you need a PIN to unlock phone, if will work fine like that for about 5-10 mins but afterwards even with the wrong print you can just swipe up to unlock the phone. now I have double-tab to wake turn on, I'm not sure if that will affect it, but is this a common issue and how can I fix
thanks for your time
61eR ®
Do you have any other security settings like setting up a location were you don't need the lock? or if a bluetooth device is near it can disable this lock?
Hi bro .. i found actually one more application what did the same u subscribed. It was smart lock .. i had the absolutely same problem and i didnt know whats going on and after more hours of finding problems i finally found that was caused by SMART LOCK from google application. I had to go to the settings, to security settings, and here on the bottom of page was "assistance of confidence" and i had to turn off this one and everything was working corectly again like before ..
"assistance of confidence" i dont know how it will be in english language because im using Slovak language in menu" but cheers guys. I hope i was helpful. Have a nice day and great fun with this awesome smartphone
sony forever
