I'm about to send my Z5 off for a screen repair. It's a small hairline crack but has rendered the screen unresponsive.
If they cannot repair the phone and offer a replacement what is the nearest alternative I could expect, given that the Z5 is no longer available?
TIA
Hi @paulyb, welcome to our forum!
Depending on what devices are available, it will most likely be something along the lines with Xperia X, or Xperia X Performance as they are the device that was released the year after the Xperia Z5.
If they aren't available either, next in line would be the Xperia XZ/Xperia XZs and so on.
I hope that helps!
I hope that helps!
Many thanks for your support. I'm still hopeful that my Z5 can be repaired but I'll review these models just in case.
Cheers!
@paulyb, you're very welcome!
Have a great day and feel free to keep me posted with which device you received!
