Sorry for my english...
The screen has an area of brighter backlight in its center. Looks like a brighter horizontal line, especially on white backgrounds. So the most material apps are very uncomfortable to use!
Don't expect the worse, it's a new phone and if you didn't drop or damage it then it might be a manufacturing defect. I assume also that you have warranty, so just go and get it examined by authorized professional.
I'd try first to boot in safe mode and check if it occurs there, just to make sure it's not a software issue. But most probably it's hardware, and I strongly suggest that you contact your Local support to get it examined.
It's 100% hardware. I'm just affraid, Sony will not repair it, as it was with Z2 Tablet.
