Before the phone learns your behaviour it can be a bit tricky to predict the battery time for the phone. Give it a few weeks and it will hopefully be more accurate, it takes some charging cycles before the battery reaches it maximum capacity as well.
With Li-Ion batteries, there is no exact charging pattern. What is more important is not to let the battery completely discharge too many times.
Anytime.
