I have had the xperia z for a few weeks now, its hands down one of the best that i have had ever and i have had them all.
However, i have noticed something very annoying. Every time i reboot the phone the icons on the home screen draw do not respond. There is an animation as if they are being pushed BUT nothing opens. Chrome, Messaging for exmple. Further more when i go into the apps draw they seem to be just as bad and open only after several pushes.
To me, a phone that costs GBP 500+ should not suffer such issues. Also, the issue is only remedied by doing a full factory re-set, which i less than fun as you lose all of your apps and stored data each time you do it.
Has anyone else had this issue? I cant locate similar threads through google search, i apologise if this is already raised, would appreciate some insight.
Also - SONY SUPPORT - please shed some light on this annoying issue. I took my first handset back because of this, but have noticed EXACTLY the same issue with the second!
you don't need an antivirus, I've seen a lot of issues with antivirus, taskillers, battery apps, ram apps, boosters, etc
I have not seen that issue on my Xperia Z you should try to update and/or repair your phone with either PCC or SUS, also those apps that are acting up did you sideload them or are they from the play store?
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
thanks - question - how will these downloads remedy the issue? does no update happen OTA?
Thank you both for responding really appreciate it
these apps are the ones that come factory loaded with phone mate - chrome, messaging, phone and playstore themselves
not all updates are OTA, but if there's a bug or something acting up on your phone, it doesn't hurt to repair the software, so update/repair your phone (reinstall)
Thanks mate, i downloaded and am installing now, lets see how we get on and ill respond shortly. Its a real drag having this issue and having to reset all the time!
make sure to
1) restart your PC once you are done installing SUS
2) disable your firewall and/or antivirus then run SUS
I think its just a bug
Do you have any antivirus or taskillers installed?
On the phone itself? now you mention it - i saw mcaffee on there actually, it came pre-loaded - really good point, while im waiting ill uninstall and then reboot and test
