I have the the same issue with the gyroscope not working, but also the accelerometer and proximity sensor not working. It seems to me unlikley that it could be a hardware component failure (all three fail at the same time?) Perhaps mine will 'mend' itself? If not I investigate the repair / replacment route.
me too !!! solved after resetting phon but again stopped !!
Does anyone have a solution to this yet.
Mine stopped working, I then did the recent android update, no joy.
It then started working for a few days and stopped again.
I get no response from gyro or accel in the service test.
Very annoying as my pictures don't rotate and google skymap has no idea where I am.
Sony needs to sort this.
I have just done a factory reset and no joy.
did the service test just to confirm
*#*#7378423#*#* in phonepad/ dialpad > service tests >
gyroscope - fail
accellerometer - fail
proximity sensor - fail
getting ever closer to a warranty issue i'm afraid.... I'm trying to avoid loosing the phone for several weeks (my experience last time) but I think it will be the only alternative.
Hi, Same problem here
I've heard tha a new 4.4.4 update is rolling out so I'd like to know from people who got the update whether it's fixed or not
because I've flashed my device back to the old 4.3 firmware because of that and I don't want to update until I'm sure the gyroscope will be working
hello.
I have the same problem onmy xperia z3.
I used the phone on the pool, taking some pictures.. My phone works good but the accelerometer and gyroscope do not work properly.
I did the factory test *#*#7378423#*#* but all the test are negative
Anyone get any joy on how to fix it? The gyroscope on my Z3 stopped working a few days ago and had no luck doing a system repair. Avoid this phone, the build quality is terrible the screen smashed from a small drop that even a Iphone would of survived. Get the Z1 they're bullet proof and have a built in screen protector.
