Xperia Z2 (D6503)(Lollipop 5.0.2)(23.1.A.0.726)
Wifi and bluetooth won't turn on after I disable airplane mode after I woke up
I already tried rebooting, safe mode and factory reset but it still doesn't fix it
Any resolution?
If Wi-Fi and/or Bluetooth does not turn on and you have performed a software repair via PC Companion, it's unfortunately not much more we can do. I suggest that you have your phone examined by a technician at an authorized service center. You can contact your local support team for information about nearest service center and/or how to proceed with this in the best possible way:
http://support.sonymobile.com/global-en/contactUs/
Did PCC repair just now, everything clean and the problem still here. Wifi and bluetooth still won't turn on.
forever turning wi-fi on...
Wifi and bluetooth successfully worked for once but it can't connect to any network, then I can't turn it off anymore.
yesterday i notice i cant access any wifi connection and continuing dropping.
i check wifi its always connected even during sleep.
i turn off the wifi. i reset the router. when i last check no more response
from wifi even the bluetooth. i reset my z2 and its still disame.
what should i do?
please help me.
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable. If PC companion does not start the repair process, you might need to run it in compatibility mode with Windows 7 (in some cases XP).
i already do that process and still desame.
