I have a z3 compact and I would like to know if I immerse my mobile under the water (without exceeding the limits of course) can the guarantee cover a fault in the audio port?
That's correct, as long as the other covers are firmly closed and there's no physical damage then it should be fine
Hi Rodri40301,
Welcome to the community!
You can also read some more detailed information on water and dust resistance. Take note of the basic care instructions.
