I have no shortcut for the Walkman on my Sony Xperia Z in the lockscreen. I can swipe to the right to launch the camera, but swiping to the left just brings up a blank screen with a plus sign to add widgets.
Any ideas?
Thanks!
Yes it appears only when the song is played.. so the new update does not have a music lockscreen widget support unless you play it
Thanks! Sony have given me the same answer too!
