My vpn connection doesn't work.
Setup is: L2TP/IPSec with PSK to my private network.
Since my old device (Xperia S), which is on android 4.3.X, is still working
I don't see any configuration problems, but I guess that this is a problem with android 4.4.X
The same problem occurs on my sony tablet z since the update to 4.4.X
Is there any fix from sony?
I read about a google fix, which should be in place on version 4.4.4, but the update to 4.4.4 on the
tablet does not solve this issue.
Sorry Richard, I found a workaround and never returned to the forum. Do you still want a pm with data? Ipsec VPN still doesn't work on the z2 tablet.
@xmacewin- I bought vpncilla, was the only way to have ipsec VPN working.
Yes, that would be great. There's no known issue with VPN so to forward this for further investigation i need more information.
This has been solved in a software update for Xperia™ Z2, Xperia™ Z2 Tablet, Xperia™ Z3, and Xperia™ Z3 Tablet Compact. For those devices, you can fix the issue by updating your device to the software version 23.4.A.1.200 or later.
For the Xperia™ Z1, you will be able to fix it when the upcoming software version 14.6.A.1.210 is released. For Xperia™ Z3+ and Xperia™ Z5 devices, work is ongoing to include a fix in upcoming software updates.
When you have updated the software, you can add the VPN L2TP IPSec in your device.
I just ran into this issue on my tablet also, and I see it is fixed or will be fixed on a number of devices. But will this also be fixed for the Xperia Tablet Z (SGP311)? Because I assume with the line:
you mean the phone. My tablet is on 10.7.A.0.222. Will there also be an update for my device?
I'm afraid i'm still waiting for more information regarding this and Xperia Z/ZL/ZR/Tablet Z. As soon as i have information about these models i will let you know.
