x
USB OTG Ethernet issue
ryuseiken
Visitor
Hello, I found a post where I saw that it was possible connection through one Ethernet cable and a USB OTG ethernet adapter, specifically here:
http://www.davebennett.tech/connect-android-to-ethernet/
I tried this on my Nexus 7 2013 6.0.1 and it has worked properly. No need to do anything more to remove the wifi connection and get an icon like this > .... < to confirm the internet.
Same cables, otg I connect my Z5 and I'm finding OTG system. I said nothing is found, in fact not the current LED lights ethernet adapter. It is a firmware failure or simply no power? Anyone else happens or you can try to confirm?
A greeting.
Sorry for my writing in English if it is not correct or not understandable.
16 REPLIES 16
profile.country.GB.title
Uliwooly
Expert
@ryuseiken
You might want to contact your Local support regarding this.
ryuseiken
Visitor
Hey, no one else has been able to test the question? I still think it's a matter of firmware enabled there is not something in my Nexus 7 runs smoothly.
Salu2.
profile.country.IT.title
Bhonder
Contributor
You could try with one of those "splitted" Otg cables which supply power to the discrete device. There are many on online markets and they are cheap.
Maybe it is only a requested power problem.
JoeUKUS
Visitor
I have a Xperia Z5 Premium Dual E6883 and I used to connect it to ethernet using Sony's OTG cable, until I updated the mobile to Marshmallow. But after the upgrade, the phone is no more detecting this usb to ethernet adapter (from plugable.com).
I contacted Sony support multiple times, but no proper response.
Recently another update came to my mobile, still no difference - it was a good feature to connect to ethernet to download all the data heavy app updates and attachment downloads, photo uploads etc. But it is no more possible.
But I hear that the stock android phones are detecting usb to ethernet adapter on OTG. It's really disappointing to see that Sony disabled this feature, after I ended up spending $700 for this phone.
Andreas083
Visitor
Any luck?
josephklj
New
Nope - fed up of chasing Sony support, I returned the phone. Ended switching back to my iPhone - which connects to ethernet (though I have to use two cables and a USB hub) and also got a Microsoft Lumia 950XL (got a free docking station as well and connects to Ethernet with a single USB adapter - works like a charm, especially because the docking station charges the device, unlike iPhone).
Sony lost a loyal customer.
serviceman
Visitor
I think sony support can not really help.
They too busy avoiding support and ingore feedback from common user.
They running the path of Kodak. (Closing Soon)
jussin
Visitor
Hello JoeUKUSa i thinkbthere is a new charger for apple ligthning that allows for usb otg and charging at the same time and should work for the purported case see youtube post how connect ipad ethernrt airplane
jussin
Visitor
I had similar experience on z3 after updating to a specific lollipop version earlier version if 5.0.2 would work after some other update the ethernet functionality was gone so i had to downgrade there is a post on youtube how to downgrade all xperia you need to find correct firmware not very satisfactorly method though as the update should have brought more stability
