where is uk unbranded 4.2.2. website says it's out but can't get my phone to update:smileyplain::smileyconfused:
for future reference use the search box
you have 2 options
1) wait, wait until the update its approved and released in your country/carrier
or
2) manually update your phone
http://www.sonymobile.com/global-en/software/phones/xperia-z/
You may already have the latest software, depending on the date of purchase. Software updates are released at different times depending on operator and/or country. Therefore, we cannot give you an exact date for when a specific update will be available for your device.
Android version: Google Android 4.2 (Jelly Bean)
Latest available software: 10.3.A.0.423
Release started: 2013-06-24
To find your device’s current software version:
Settings > About phone > Build number / version
if it says 4.2.2 is out for UK unbranded give it a few hours for either Sony PC Companion or Update center to detect it
when update just rolled out to 3 SE in sweden it took me like 1 hour untill Sony PC Companion to detect it, so when i checked after 1 hour then a pop up box came saying 10.3.A.0.423 update available
Just checked is your phone the Generic UK? if so i can still see it's on
still 😕
you have 2 options
or
unbranded UK phones havent got update yet since they are still on firmware
which this site here is telling me
http://forum.xda-developers.com/showthread.php?t=2315914
it says United Kingdom Generic UK 1270-7689 10.1.A.1.434
you can get real status at http://scavenger.ch/sonyupdate
find your phone customization version by doing the following
Your customization number can be found in your service menu (dial *#*#7378423#*#* > 'Service info' > 'Software info' > 'Customization Version').
then use it on second link select your phone model and press the refresh button then you should get real status on which firmware it's on
