After updated to Marshmallow 6.0.1 the error message pop up "unfortunately system ui has stopped"! The only way that I know to solve this problem is removed the sd card.
How to solve the problem?
Topic edited by Rickard
I don't think is SD card problem because it worked on other smartphone
Strange, I think I've seen this on other devices that recently updated to 6.0 in other boards (Z3,Z3c). Try to boot in safe mode and check if the same occurs.
i got the same problem after update, the problem is solved after i reboot phone. maybe just a glitch
Thanks, I'll try this method later.
By the way, how to tag people when I want to reply the message?
I tried reboot a few times but the problem is still there.
By the way thank you.
I'm very sorry to hear that.
When this happens, are you able to access the phone and its menues? If so, would it be possible for you to take a log from the phone and send it to me?
To do this:
Settings > About phone > Build number, tap 7 times on the build number
Go back to Settings and select Developer options and turn on "USB debugging". Then tap "Logger buffer sizes" and set this to "4 M".
- The next time you get the error message:
Settings > Developer options, select "Take bug report". When the report is ready (may take a minute or so) you get a notification that you can tap and share to Google Drive. Please send me a link to this file in a private message.
