When I try to transfer data from the internal memory to my SD-card i get the message "unfortunately memory has stopped". The SD-card has worked before as well as the transfer feature. I think this started to happen after a warranty repair of my 3.5 mm stereo connector. Any clues about what to do?
Did you try to remove the SD card and put it back again?Also,restart your device with the card inside.
@alexdon wrote:Did you try to remove the SD card and put it back again?Also,restart your device with the card inside.
Yes, I tried that, still no luck. I also tried with a different SD-card and it still doesn't work.
For me i get unfortunately bbm has stopped whenever i try to launch the bbm app, also same for my album and movies app...this is frustrating, i really need help.
I suggest you download SUS and attempt a repair:
http://www.sonymobile.com/gb/tools/update-service/
Settings-storage-erase SD card.
