See the solution from the topic:
/t5/Software-Updates/Downgrade-Z3-compact-and-others-from-Lollipop-to-KitKat/m-p/955661#M19200
Please see this thread:
/t5/Software-Updates/Downgrade-Z3-compact-and-others-from-Lollipop-to-KitKat/m-p/955640#U955640
It is applicable to any xperia.
Yes, downgrading does not require nor root neither unlocked bootloader.
Although, need to be careful that on some markets not having the latest firmwre update might mean warranty is void. So please contact your Local support .
Contacting them or downgrading? To contact, click on the blue writing in my upper post.
