Hello, since i updated to 5.1 there is no more the throw symbol/button in the notifying drop down menu... Before there used to be it. Is there any way to get it back there? Thx
Hi @Swirlin,As far as I know it should still be available though you may have to add it the way @uliwooly described.Edit: You can also have a look at this link
We're glad to help!
@Swirlin
Anytime
