I was listening to the FM radio for the first time on my experia zl and the whole thing froze. It will not respond to anything,
I can hold the start button for 5 minutes with no response.
Is anyone else having similar problems?
Did that, just did it again... nothing.
Held the Power button and volume UP... 30/40 seconds...nothing
Held the Power button and volume DOWN... 30/40 seconds...nothing
It seems I will have to wait until it runs out of power and then restart it. The screen is stuck on fm radio, 91% power, 1:14pm eastern standard.
I've had since April15, if it's still like this by the time I head home, it will be going back to Costco.
Thank you for trying.
try this
remove the SIM card and put it back on, it should restart your phone
Stuborn little device, still no change with this procedure.
While doing this I noticed a number CE0682 would this be the build #?
Maybe it just doesn't like the blues. lol:smileysilly:
so even after pressing power & volume up at the same time for 10+ seconds, or removing the SIM card the phone is still stuck (on) ? that's quite interesting, press and hold the power button for 20 seconds. this is quite odd
the build number will be
settings > about phone > build number
10.1.A.1.434 or so
once you get the phone to restart use SUS to repair your phone or return it/exchange it
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
for future reference
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Did that more than once for more than 20 seconds, didn't do anything.
It's now been on the same screen for 2 hours 45 minutes, nothing works.
Thanks a lot for your effort
following this with interest - SusyD you have an anomaly in your hands - some people have an issue with turning on but never turning off
have you definately connected to your PC via USB and tried to do an update repair ? download Pc Companion from Sony (do a search)
do you have a memory card inserted ? if so remove it
plug in headphones and see what happens
this is pretty weird
is the phone doing anything at all - does the battery indicator show a drain - is it going down
is the clock changing time
