I've been using my Z5 Compact with all options underneath Stamina Mode switched on, however, I've noticed that upon picking up my phone to use it, the data connection isn't instantly available, rather I have to wait for 10 seconds or so before I can use any data.
I've been trying to isolate where the issue lies and it seems that as long as I have Stamina Clock disabled, all is well. I've only noticed this since the recent firmware update, but not sure whether that is the cause.
Has anyone else experienced this issue?
The delay is still there in 32.0.A.6.200 i'm afraid. The update with a fix for this will have a later software label.
Stamina clok off fix this on me but i want use it. When we get update to this ?
I'm afraid i don't have any information regarding when the update will be available.
until the update package, I close the stamina mode because cuts the WiFi connection in sleep mode.
Extended standby under stamina mode is supposed to do this.
But if you also enable stamina clock there may be a delay before the connection is reestablished when you turn on the display. That is what the upcoming update will improve.
@Rickard
wifi connection again lost while stamina mode even switched off.
I never had this problem before my cell phone.
Have you checked so that "Keep WiFi on during sleep" is set to always? You can find this setting under Settings -> Wi-Fi -> [menu] -> Advanced.
Note that if you go out of range from your network, Z5 will not reconnect automatically when you're back in range unless you turn on the display.
yes it is set to always. telephone standing on the table, its position not change.
