A seguito di reset del telefono non riesco piu ad attivarlo. Le relative voci delle impostazioni sono grigio chiaro non selezionabili. Grazie.
fter resetting the phone I can no longer activate it. The related setting items are light gray not selectable. Thank you.
gt
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Are you referring to
settings > Language & input > Spell checker
does it say No apps with spell checkers installed ?
@ceciliabramucci911 wrote:Spell check disabled
After resetting the phone I can no longer activate it. The related setting items are light gray not selectable. Thank you.
