Unless I'm blind to miss it, does anyone know of a way to set the sort order in Contacts. The default seems to be "Firstname Lastname" and I'd prefer "Lastname, Firstname". I can install Contacts+ which does offer that option, but it goes all overboard with trying to do all sorts of other stuff I don't want/need.
Andries
same as my above post but open filter - sorry I left that out
contacts 3 dots menu (bottom right) - - list by last name - sort by last name
helpful or not
That's where I expected it to be as well, but no luck. The only options I have in the ... menu are:
* Import contacts
* Back up contacts
* Mark several
* Filter
* Find link candidates
* Settings
This is the default "Contacts" app that came with the Xperia Z on the first App screen.
My, I feel such an idiot.
I saw Filter and immediately dismissed it as not applicable to sort order and just didn't look further
*hang head*
