Hello,
My Sony Xperia Z3 After replace new Screen , i tested screen that was work true , But after fix it that no Image , not working and see Red light ...
after alot of try telephone active with sony pc companion ... and i flash it with android 5.1.1
i hear sound when i turn phone On .. but no image in screen ... i try change with new screen but no image too.
when use charger i see red light 15 Second after that Orange light.
iam technician ,
wait help and thank you
Either the flex cables are bad or the new screen, it could be that the damage was more than just the LCD and perhaps even the motherboard.
if you have a MHL 5pin cable you could connect it to a screen and then see if the phone its working
