Currently using that Shake opener. Very helpful.
Though having no top side of your screen is pretty irritating as you can't use apps that need to click some part of your screen in the top (ie. Instagram).
Yesterday the problem occurred to my z3c too. Softkeys are gone! i've tried factory reset, xperia companion software repair, reset button... what should i do? i have more or less 6 month of warranty, should i bring my phone to Sony customer care?
Yes, bring it as soon as possible. No other reliable method exists and you are lucky if you have valid warranty.
I'm no expert but the following worked for me.
It seems an app was installed or upgraded that invisibly smothered the screen and prevented interaction.
1. Goto Settings / Apps / Settings (cogwheel) / Draw over other apps / Change all the apps to "No".
2. If you have installed the "Back Button" app, goto Settings / Accessibility / Back Button / Turn off.
The above got it working again - just.
Then goto Settings / Display / Glove mode / Turn on.
Worked a treat. Good luck.
@miniss45 wrote:Hi,
2. If you have installed the "Back Button" app, goto Settings / Accessibility / Back Button / Turn off.The above got it working again - just.
Then goto Settings / Display / Glove mode / Turn on.Worked a treat. Good luck.
Tried for the apps that'd allow it, didn't work. Am I missing something?
Whole last year I have expirienced differend display glitches with home and minimize button and sliding top menu but it did fix itself after some automatic updates or phone restore.
This time the phone became completly unuseful, all my bottom buttons have stopped working at once and restore won't help anymore. I don't want to wait another 3-4 month to get them fix it.
From all my previous experience I believe it is a software issue. Sony just do it again and again and doesn't learn any lessons out of it. The updates should be well tested before they release it.
I'm going to switch to cyanogenmod and see if it does help.
There are more then 30 pages of complaints here from different users about the same issue but looks like Sony sadly copmpletly ignores it.
Sony z3 compact xperia back and home button not working
I love Sony products very much and user of Sony mobiles & TV's, Music Systems for more than 15 years and for last couple of years i am losing hope on Sony products since my Sony LCD TV had display issues and i have scrapped it. The TV was just 3 years old and now facing problem with Xperia Z3 Compact
I bought Z3 Xperia Compact a year back at Sony Centre, Annanagar, Chennai and to my surprise they have sold me a secondhand piece and within 10 days i faced an issue and took it to Sony Authorized Service center where they disclosed in written stating that the mobile has been already serviced before 4 months and after lot of fightings they replaced me with a new one after 40 days.Its been one year now and facing toch screen issue. Surprice to see 34 pages that too with same issue.
More over a week back want to replace the SD card plug cover for which the service people told me only if i surrender the phone they will place order for spare and the beauty is they may take atleast one week or more for replacing a simple spare and till the time the hand Set has to be remain under Sony Service center. i was even ready to pay the demanded amount as advance and still they never accepted myrequest.
Sony is no more my favourite product.
