An official from Sony can at least confirm that this PB is studied ? @Christofer ?
Come on SONY Mobile!!! Help me / us to fix this problem......with due respect, PLEASE.
I have the same problem, when I run the diagnostics for the proximity sensor it is ON all the time. So I guess that some thing the last SW update, big time. Either the sensor "just got a bug" in the code OR its crapp now.
And as it appears here on the support forum, Sony is neglecting us... Maybe time for a Apple 7
Try this. It worked for me. The problem I had was the home and recent apps buttons not working and I couldn't pull down my notification/status bar.
1. Download/Install/Open "Nova Launcher".
2. Long press home screen, select widgets.
3. Create a nova activity.
4. Scroll till you find Setup Wizard.
5. Look for SetupWizardTestActivity.
6. Click on the icon you just created.
7. Run through setup.
Explanation of the problem here:
http://infomash.net/home-button-not-working-after-updating-to-android-marshmallow/
https://www.virag.si/2015/08/home-button-not-working-after-flashing-to-android-marshmallow/
I've got this problem with my Z3 Compact now. Just one year ago I'd got the faulty motherboard fixed. New problems keep popping up with this phone. Sony makes people pay premium price for cheap quality products. I could have picked up an iPhone or a good Samsung for about the same price, instead this horrible phone. Never buying a Sony product again.
After the latest software update I experience the same issue. At first the touch screen was extremely sensitive. I have been able to resolve this by going into Settings – Apps – Running apps and force stop com.sonymobile.touchscreen.touchfilter.tfpss.
However, since two days I can no longer use the home, back and folder button at the bottom of the screen. If I hold the phone upside down the buttons apear at the top of the screen and then it works. But this is not a very convenient solution...
I would expect software releases to be thoroughly tested before going live. However, something went definately wrong here. Sony please send another update which will make things work again!
As proposed by the Sony helpdesk I have uninstalled the latest software update. However, this does not resolve the issue!!! And you will loose all your applications from your phone, so I do not recommend this!
Please come up with a better solution to get this resolved!!!
