Thanks a lot for the powerfull information, it works well now
This is so great! I used ADB without any knowledge about it, just using the instruktions and it worked right away.
Thanks a lot. My "Brick" is alive again.
I'm very upset with SONY. I'm using a Sony Z3 compact, and I've been having issues such as my headphone jack doesn't work, and now my bottom buttons do not work.
I'm done with this product, I had high hopes. But, this is too much.
Do you have an Z3 Compact or a Z5?
/t5/Xperia-Z5-Z5-Compact-Z5-Premium/Headphone-jack-not-working/m-p/1269566#M41264
if both, do you experience the SAME headphone issues on both your devices?
I have a Z3 Compact. I heard issues with Z5 as well about the headphone jack.
I have the same problem
Hello,
I have the same problem.
Some of you reference some "ADB Tool". I can not find this in the playstore.
I tried for a workaround the "soft-keys" app. It works fine, but gives me the
"Display-Overlay detected" problem. Thus I can not configure any app
without disabling the soft keys. If I do so I can not use my phone.
Thus my phone has very limited features and is hardly useable.
Can someone summerize the solutions posted in this tread? Especially those that are currently working?
I tried all ideas from support such as restart, safe mode, software repair. None of it helps.
Here are some instructions that may be helpful:
