Thanks for the tip of press below icons , so I verified that if I use a larger finger , not works as it is more accurate now them it works better using small finger !
Hi all,
I put on Glove Mode as a workaround. If i slide slowly from the bottom it works.
My Z3 Compact has stopped responding to the bottom buttons (back, home, multi). Using Developer Menu and tap visualisation, I noticed it simply does not register taps on button bar. I tried:
Any ideas? Or this phone is as good as a brick now?
It's as good as a brick now I'm afraid. I had actually been contemplating buying a new XZ1 Compact well before this latest software update. Having seen how arrogant Sony has been behaving by completely ignoring the issues with the update. All the consumer feedback...they don't care.
So...no more Sony products for me. I've switched to Huawei and is not comming back...
if you want to try the risky method you can try to fix it with cricket electronic gas lighter, the detail how to do it see youtube with keyword "mengatasi touchscreen error menggunakan korek api cricket"
or you can try my safe way, by using usb otg attached with mouse
so my mouse work as pointing devices in my z3c screen,
i know its ridicilous but at least i can use my z3c
@bonggo, glad to know that I am not the only one that is using OTG + Mouse to control this unworthy device. @sony, before I know that you are too arrogant, I was thinking of upgrading to Z5 Compact and buy a smartwatch. Now no more business from me or my family.
My story in a nutshell:
I receive an error message after entering "adb shell wm overscan 0,20,0,0"
Any ideas?
thomasic$ adb shell wm overscan 0,20,0,0
java.lang.SecurityException: Must hold permission android.permission.WRITE_SECURE_SETTINGS
at android.os.Parcel.readException(Parcel.java:1553)
at android.os.Parcel.readException(Parcel.java:1505)
at android.view.IWindowManager$Stub$Proxy.setOverscan(IWindowManager.java:1206)
at com.android.commands.wm.Wm.runDisplayOverscan(Wm.java:192)
at com.android.commands.wm.Wm.onRun(Wm.java:78)
at com.android.internal.os.BaseCommand.run(BaseCommand.java:47)
at com.android.commands.wm.Wm.main(Wm.java:45)
at com.android.internal.os.RuntimeInit.nativeFinishInit(Native Method)
at com.android.internal.os.RuntimeInit.main(RuntimeInit.java:249)
back ,home botton doest not function
Issue for me started with the top notifcatin bar not sliding down.
Now its the bottom navigation bar that is no longer working.
This is clearly a hardware issue just as others have mentioned.
I have the Z3 Compact for about 25 months now.
My only work around that I think is the best solution is if you have Xposed installed, you can use this app: Dimensions editor
http://repo.xposed.info/module/com.hamzah.dimenseditor.
You can easily change the height of the nav bar or notifcation bar.
Slowly loosing screen realestate and burning long time faith in the brand.
Thanks Sony.
