- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
July 2020
July 2020
Sony z2 açılmıyor ?
Sony z2 telefonum yazılımsal sorunu var bazen açılmıyor.
Format veya resetlemek gerekiyor
Bu işi telefoncu yapmakta
Bana nasıl yardımcı olursunuz.
Programları veya bir yolu var mı?
2 REPLIES 2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
July 2020
July 2020
Hi Deepex, welcome to the community.
As this is an English language community please can you post in English if possible. You can try to use Google Translate or deepl.com if that helps.
Best wishes,
Ed
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
July 2020
July 2020
Hi @Deepex
I have let translate.google.com translate your question.
If you want to reset your Z2 you can goto settings and search for reset or you can use Xperia Companion and do a software repair.
Check that you do backup your data first.
More information can be found in the Xperia Z2 manuals .
