Hello,
I just got my XPERIA Z5 and i want to ask about my camera in low light. When i start the camera in low light, it is so dark and i get that blurry screen like with dots. There is something that i do wrong or my camera is defect. Because on the video from SONY it said that captures at low light doesnt matter how low it is. (btw i am not talking in very dark places without light, with lamp or sometihng)
If you know what is the problem please let me know and if you don't understand something i wrote ask i will explain better if i can.
On manual and on auto same problem. I don't know how to explain i see only 23 mp, iso auto( on manual is auto lol), hdr off.
I don't know is this what you are asking for.
@uliwooly
THIS IS ALSO MY PROBLEM
When i wave with my hand, or capturing moving object and when i take the picture it is not like it is used to be...
@Phy
This is working the same as it is on the post in 2016? Because the post is from 2013
I don't know what settings to give you :@ I don't understand u either...
Can you help me how to set the phone so when something is moving i can capture clear and good
If you are attempting to take extremely low light pictures of something moving that's not going to happen, it will be blurry, even with a DSLR.
What I meant is, open the camera > are you using SuperiorAuto or Manual, if the later, what other settings are you using?
My problem: now (after some days) I cannot change the (in french) "Automatique supérieur" option.
I have lost the yellow icon of the camera, it is white and like disable... I can touch it: "Automatique supérieur..."
(for an Xperia Z5)
S.O.S. !!!
